Me Rob or him Rob ???
Me Rob got nothing left from the stock set up...
Rear:
8.8 SRA
3.73 Gears
Eaton Posi, “upgraded”
Moser 31 Spline Axles
Trans:
PA #45102 Super Comp 4r70w
Alto Red Racing Clutches
Heavy Duty Servo
Hardened Input Shaft
Kevlar Band
Drum & Diode
Deep Aluminum Pan
Manual Transbrake
PI 3500 Triple Disc Lockup Stall Converter
PI Manual Valve Body
Electronic Over Drive
Electronic Convertor Lock Up
Chromoly Driveshaft
Suspension/Brakes:
Front-
UPR Chromoly Tubular K-Member
UPR Chromoly Tubular Control Arms
Strange 10 way adjustable Front Struts
QA1 250lb 14" Coil Over Springs
Global West Caster/Camber Plates
Wilwood 6 Piston Front Brakes with Drilled/Slotted 13" Rotors
Rear-
Steeda LCA's
FMS UCA's
Eibach Coil Springs
Airbags
Adjustable Shocks
Wilwood 4 Piston Rear Brakes with Drilled/Slotted 12" Rotors
No wheel hop or 1/2 shaft worrys over here
My problem is the brakes were added afterwards and I didnt get the old Brakes or Rims when I bought it
