One of the coolest features of the 2012-2013 Mustang Boss 302 is the quad exhaust system that utilizes two additional exhaust pipes that break off from the main system, exiting out just ahead of the rear wheels and resulting in a truly unique sound. Ford even allows owners of the Boss 302 can also change the aggressiveness of the exhaust note by adding or removing restrictor plates in front of the side pipes.
Unfortunately this requires crawling under the car and unbolting the pipes, which doesn’t take much time but can be a hassle. Fortunately Quick Time Performance has an easier solution with their new electric cutout system. Constructed of high quality aluminum and stainless steel, the electric cutouts allow owners of the Boss 302 to open or close the side exhaust system instantly with the flip of a switch. The system includes weather proof wiring harnesses, a high torque DC gear-driven motor and a full metal motor cover with a powdercoated satin finish.
Quick Time Performance Boss 302 Electric Exhaust Cutout Features:
- CNC 6061 Aircraft Aluminum Body
- Full Metal Motor Cover/ Powder Coated Satin Finish
- Stainless Steel Butterfly Plate
- Stainless Steel Shaft
- 6061 Aircraft Aluminum Motor Plate
- High Torque DC Gear Driven Motor
- Gears Made from High Temp Steel for Long Life
- 2 position Momentary Toggle Switch
- Weather proof wiring harnesses
- Weather tight Connectors for Superior Sealing
- Proudly made in the USA
