Nice! ^^^^ what the details one the White Cobra becides the 331 (and SC?)
ENGINE
*DSS 331 super pro bullet
*AFR 165 heads with upgraded springs
*FMS roller rockers
*Anderson b41 Cam
*Ford racing lifters
*Melling HV oil pump
*Canton 7qt Oil pan
*Vortech V1 S trim
*Anderson Power Pipe
*Elderbrock RMP2 intake
*Elderbrock 70mm Throttle body
*FMS timing chain
*FMS Water pump
*Fluidyne Aluminum Radiator
*Pro M 92mm Mas Air Meter
*60lb siemens deka injectors
*Elderbrock 255 Intank pump
*Vortech External Pump
*Aeromotive Fuel Pressure Regulator
*MSD 6AL
*MSD Blaster 2 Coil
*Hurst Line Lock
*Kooks 1 ¾ Longtube Headers
*Kooks off Road X pipe
*Kooks Custom Tailpipes
*Borla Xr1 Race Mufflers
*New OEM Motor mounts
DRIVETRAIN
*Tremec tko 600
*Tremec bell housing
*Spec Aluminum Flywheel
*Spec Stage 3+ Clutch
*Steeda shifter
* Fiore firewall adjuster
*Torsen Differential
*Moser 31 spline C clip axles
*Aluminum Drive shaft and safety loop
SUSPENSION & CHASIS
* Bilstein shocks and Struts
*H&R super sport springs
*MM Spring Isolators
*MM Aluminum Rack bushings
*MM Caster Chamber plates
*MM Panhard Bar
*MM Strut Tower Brace
*FMS Front Control Arms
*Steeda X2 Ball Joints
*Steeda Bump Steer Kit
*Steeda HD Sway Bar End Links
*Steeda Rear Billet Aluminum Weight Jacker Control Arms
*FMS Rear Upper Control Arms
*Global West Sub Frame Connectors
*Saleen Stress Bar
*Saleen Front Sway Bar
*Brembo Big brake kit up front
*Stainless Steal Brake lines
*Hawk Brake Pads
*Wild Rides battle boxes
INTERIOR, EXTERIOR AND WHEELS
*CCW 505A wheels 19x8/19x10
*Michelin pilot sport 255/35/19 Upfront 295/35/19 outback
* Corbuae LG1 microsuede Front seats
*MMR Rear Seat Delete
*Autometer phantom,boost,air/fuel,water,oil,fuel pressure and volts gauges,
* Raptor Shift light
*Smoked Head lights and Fog Lights
*keanen Saleen S281 wing
*96 tail lights
*Cervini 95 Cobra R hood
