Where do you buy the gears to correct the speedo after a rear gear change?
Chevy_Guy Well-Known Member Jun 4, 2011 #1 Jun 4, 2011 #1 Where do you buy the gears to correct the speedo after a rear gear change?
92BIGREDBEAST Well-Known Member Jun 4, 2011 #2 Jun 4, 2011 #2 You ask, you shal recieve! This place is the best! speedometer gear - LRS Search
Chevy_Guy Well-Known Member Jun 4, 2011 #3 Jun 4, 2011 #3 92BIGREDBEAST said: You ask, you shal recieve! This place is the best! speedometer gear - LRS Search Click to expand... Awesome. Now do the math and figure out what gear will be needed with stock size tire and either a 3.73 or a 4.10. I am taking out 2.73's and throwing them in the river.
M MIKE NY Member Jun 4, 2011 #4 Jun 4, 2011 #4 did the same about ten years ago...LOL 23 tooth for 410s and 21 for 373s
Chevy_Guy Well-Known Member Jun 4, 2011 #5 Jun 4, 2011 #5 MIKE NY said: did the same about ten years ago...LOL 23 tooth for 410s and 21 for 373s Click to expand... Thanks man. Ordered tires tonight and about to order gears.
dsblk93gt 5.0 Moderator Jun 5, 2011 #7 Jun 5, 2011 #7 http://www.allfordmustangs.com/photopost/data/5402/Speedo_gears.jpg Click to expand... BTW you can get a Jeep 23 tooth gear part # J316739. Not sure on the cost I'd have to look tomorrow at work.
dsblk93gt 5.0 Moderator Jun 5, 2011 #8 Jun 5, 2011 #8 Phil, order a shift kit for that AOD too while your at it....
