GETTING OUT OF RACING
89 coupe
paint is 2 years old it has a 5.5 in extended cowl hood
interior
full 10 point with window net will cert for 8:50's
sub frame connectors
upper n lower battle boxes
10 gallon fuel cell welded in 2 spare tire well
brand new grey carpet
gery interior
center console with painless switch panel
one summit racing seat with g-force 5 point harness
everything gutted under the dash(neatly nothing was cut)
rear seat delete
suspension
front
granatelli tubular k-member
geanatelli tubular a-arms
flaming river manual rack(quick ratio)
bbk c/c plates
ground pounder coilovers springs with 90/10
manual brake conversion
crooss drilled rotors with extended studs
engine bay is smooth
rear
upr full drag suspension
double adj upper
single adj lowers
anti roll bar welded in
motorsport c springs
rear end
8.8 31 spline c-cliped axels(4lug) with extended studs
axel tube are pinned
spool
4:30 gears
t&a girdle
15X7 WELD DRAGLITES ALL AROUND....7000
EMAIL ME ,PM ME OR CALL 646-529-6423
WILLING 2 TRADE FOR A MODDED 87-93 STICK MUSTANG
ALSO HAVE THE FOLLOWING PARTS 4/SALE
-yates c-3 heads, titanium valves/retainers, flows 350cfm intake, 230cfm exhaust
JESSEL SHAFTMOUNT ROCKERS.....3500
-je pistons, gas ported, coated sides and dome .030 BRAND NEW.....1000
-crower "hippo" lifters .875 dia......BRAND NEW .....1000
FOR ALL THE MOTOR PARTS AS A PACKAGE DEAL...5000
COMLPET CARB FUELSYSTEM....
25' TWISTLOK 8AN HOSE
MALLORY REGULATOR
COMP 250 FUEL PUMP
FRAM FUEL FILTER
TONS OF BRAND NEW 8AN FITTINGS.........................500
HOLLY BLACK FUEL PUMP....125
CUSTOM FLORIDA 50 GAUGE CLUSTER WITH SPORT COMP 2 5/8 GAUGES
ELEC TRANS TEMP
MEC OIL PRESS
MEC FUEL PRESS (CARB)WITH ISOLATER
MEC WATER TEMP
ELEC VOLTS
MEC VACUMN
SPORT COMP 5 IN MONSTER TACH....650
MSD CRANK TRIGGER..........250
MSD BLASTER COIL.....40
MSD START/RETARD CONTROL BOX.....200
MSD 6AL....100
MSD 3 STEP....50
MSD 2 STEP...40
DYNAMIC MIGHTY MITE C4 WITH TRANBRAKE
5000 STALL CONVERTOR
TRANNY COOLER(BRAND NEW IN THE BOX).................2500
89 coupe
interior
gery interior
rear seat delete
suspension
front
bbk c/c plates
rear
double adj upper
single adj lowers
rear end
spool
4:30 gears
t&a girdle
MALLORY REGULATOR
COMP 250 FUEL PUMP
FRAM FUEL FILTER
ELEC TRANS TEMP
MEC OIL PRESS
MEC WATER TEMP
ELEC VOLTS
MEC VACUMN
MSD 6AL....100
MSD 3 STEP....50
MSD 2 STEP...40
