1987' Mustang notchback Jonquil yellow also known as tropicsl and mimosa 6H paint code rare
1 of 93 original 5.0L 5spd cars (pedals still in car)
manual windows
smoked head lights
windows tinted 35%
3inch cowl hood
dual 2 5/8 gauge pod in dash (oil pressureand water temp)
8.8 rear with T/A girdle ,35 spline moser axles with spool with 4.10 gears
Double adjustable upper control arms,SSM lowers
Laurel Mountain Mustang drag springs, lakewood shocks and struts
custom made sub frame connectors with driveshaft loop tied in
QA1 tublar front k-member with stock lower arms and new ball joints
UPR Caster camber plates
Flaming River manual rack kit
Aerospace front drilled drag brakes and master cylinder,stock drums on rear still
hurst line lock
MOTOR:
SBF 347 inches
AFR 185cc heads 2.02"int./1.60" exh part #1388
4340 forged internals Eagle I-beam rods and crank
10.8:1 compression (run and race on 93oct)
SFI balancer
polyurethane mounts
electric water pump(polished)
crane cam (specs to buyer)
tie bar roller lifters
hardened pushrods
crane 1.6 roller rockers
ported edelbrock victor jr. intake and tapped for fogger set up
fabricated aluminum valve covers
AED 850cfm 4150 carb with 4 corner idle
Hooker Super Comp 1 3/4" headers
TRANSMISSION:
JW UltraBell
Rollerized TH400 Redneck Racing reverse manual valve body
Alto red clutches
transbrake
Select 10" nitrous converter
SFI flexplate
nassau drive shaft
INTERIOR:
B&M pro stick
5inch monster tach with shift light
interior is tan all stock,heater box still intact, no rollbar or roll cage,
have black carpet not currently in vehicle
FUEL SYSTEM:
12gal Aluminum cell in trunk
-10AN line to pumps
2 black pumps
ot yet-8AN to regulators
BG regulator
NOS plate system installed on car,not yet finished
IGNITION:
MSD 6AL box
MSD E-coil
MSD distibutor
Taylor 10.4mm wires
car has never been in a accident all panels are original frame rails are straight as a arrow
$10,500 or B/O Call and leave message or text anytime (551) 998-8424 John
I have receipts,videos,time slips and dyno sheets for serious inquiries.
Car has just been refreshened has handful of street test passes. Can email vids
Car has Weld Prostars with M/T 28x10.5" slicks on it, along with other parts I will throw in.
manual windows
smoked head lights
windows tinted 35%
3inch cowl hood
hurst line lock
MOTOR:
SBF 347 inches
SFI balancer
polyurethane mounts
hardened pushrods
TRANSMISSION:
JW UltraBell
Alto red clutches
transbrake
SFI flexplate
nassau drive shaft
INTERIOR:
B&M pro stick
FUEL SYSTEM:
-10AN line to pumps
2 black pumps
BG regulator
IGNITION:
MSD 6AL box
MSD E-coil
MSD distibutor
Taylor 10.4mm wires
