WTT or SELL: TKO500 for BUILT AOD
So after some thought and what i want MY TURBO 86 NOTCH to be, im putting my stick set-up for trade. Can even convert your car from auto to stick as i have everything needed for conversion
My set-up has the following:
TKO500...(around 1500-2000miles)...has been sitting in my garage) was behind 302, with heads and cam
Centerforce dual friction (new in box)
Fidanze aluminum Flywheel (new in box with weights)
MGW shifter
Tko Bellhousing (new, never used)
GM syncro mesh (if i remember correctly, 3 quarts)
Crossmember, Pedals, Quadrant (i believe its steeda), cable, fork, yoke, seperator plate, throw out bearing, lower boot, upper boot, shift knob, etc, etc
I am looking for an Built AOD, converter, cooler, etc, etc...MUST bolt right up as i have no time to fab up, or wire up...so unfortunately no 4R70Ws, No C4s, No PGs, etc, etc
PICS WILL BE AVAILABLE MONDAY NIGHT.
*******PM ME WHAT YOU HAVE OR TEXT AS IT WILL GET A FASTER RESPONSE****
BE LOCAL TO NEW YORK, NJ, PA....OR BE WILLING TO TRAVEL
ABSOLUTE MUST.....YOU MUST HAVE PAPER WORK ON YOUR TRANS-CONVERTER SET-UP, SORRY BUT NOT GETTING STUCK WITH WHAT SHOULD BE IN THERE AND ISNT....
If still installed, even better to test your set-up out...
IF IT DOESNT GET TRADED, ,I WILL KEEP IT AND SEND IT OUT TO BOB HANLON FOR THE NEWER STYLE SYNCHROS
you can reach me through PM, or email or cell
Angel 347-628-6641 text or call
m88handles@yahoo.com
Thanks guys
____________
MGW shifter
Thanks guys
____________
