VIPER T-56 6-SPEED.Faceplated by liberty and also all other options.All Metal enhancements, upgraded shift lugs The trans has a blown input shaft and lower cluster .Liberty says $1000 to $800 to fix it for the parts & labor.
$1700-$2000 for a GOOD core + $3000 for liberty to do all the work = $5000.This trans is Way stronger than a TKO 5 speed & is rated to hold 1000 hp .If you need to shift above 6500 or want to power shift with no problems this is the trans for you.this is not a viper spec cobra unit. it has the viper emblem on the side of it. 26 spline input. 30 spline output .
2 shops in the northeast that would fix it.eastcoast supercharging in New jersey , and BoB Hanalon in P.A. Both tremec dealers that deal with liberty all the time.Trans is in C.T.$1500+ shipping
CHRIS 860-919-9667
I also have access to an aluminum drive shaft and bellhousing for a 1996-2004 & a mod motor from D&D I can add for extra $300 .The bell is $300 and the driveshaft is $499 new, both in excellent condition,
CHRIS 860-919-9667
