trying to remove my calipers so i can change my rotors ....i cant get the damn bolt off no matter how hard i try!!! :nono: any kind of spray or something i can use? thanks for the help
I used this stuff called THRUST to get my manifold bolts off when I changed my exhaust.Sprayed it on ,let it sit for a couple of minutes and they loosened up
Spray it up, let it sit, use a breaker bar at least 12" long. If no go, then give it the heat, just until it turns a slight red, no need to get it lava hot.
