Canton Racing Products 80-232 - Canton Racing Coolant Expansion and Recovery Tanks
large image
- $149.95
- <LI class=cart-button>
<LI class=wishlist>+ wishlist
- + compare
- <LI class=pdetail>ALUMINUM EXPANSION TANK FOR 96-04 MUSTANG
- Estimated Ship Date: Today
- Email this page
Share
Brand
Canton Racing ProductsManufacturer's Part Number80-232Part Type
Overflow TanksProduct Line
Canton Racing Coolant Expansion and Recovery TanksSummit Racing Part Number
CTR-80-232 Overflow Tank MaterialAluminumOverflow Tank FinishNaturalShapeRectangularVentedNoRecirculatingYesDrain Valve IncludedNoInlet QuantitySingleInlet AttachmentHose barbInlet Size5/16 in.Overflow Tank MountingBolt-inMounting Hardware IncludedNoQuantitySold as a kit.NotesThis tank accepts a radiator-style cap.
Keep your cool flowing with Canton Racing expansion tanks.
Your coolant does you no good puddled on the ground. Keep the track clean and your fluid where you need it most--in your car--with Canton Racing expansion tanks.
These model-specific coolant expansion and recovery tanks are designed to fit in the same location as your stock tank. They are built from strong .100 in. aluminum that can be polished or anodized for a custom look. Canton Racing expansion tanks provide increased strength and a more reliable performance than stock plastic to prevent fluids from venting onto the ground and being lost out of your cooling system completely. Keep your cooling system running efficiently with USA-made Canton Racing expansion tanks.
