If it not set properly, and you get a air leak the car will run and drive like shit. If you dont seal the coolant passages correctly, anti-freeze will get into the lifter valley and then the oil pan. You will then have scorched bearings or worse. Spend a little now or alot later. You dont have anyone that can help you?
Come on here guys, is there anyone local that can help this guy out?
