GETTING OUT OF RACING
89 coupe
paint is 2 years old it has a 5.5 in extended cowl hood
interior
full 10 point with window net will cert for 8:50's
sub frame connectors
upper n lower battle boxes
10 gallon fuel cell welded in 2 spare tire well
brand new grey carpet
gery interior
center console with painless switch panel
one summit racing seat with g-force 5 point harness
everything gutted under the dash(neatly nothing was cut)
rear seat delete
suspension
front
granatelli tubular k-member
geanatelli tubular a-arms
flaming river manual rack(quick ratio)
bbk c/c plates
ground pounder coilovers springs with 90/10
manual brake conversion
crooss drilled rotors with extended studs
engine bay is smooth
rear
upr full drag suspension
double adj upper
single adj lowers
anti roll bar welded in
motorsport c springs
rear end
8.8 31 spline c-cliped axels(4lug) with extended studs
axel tube are pinned
spool
4:30 gears
t&a girdle...........................6000 FIRM!!!!!
EVERYTHING IS BRAND NEW....I HAVE CLOSE 2 9500 IN THE CHASIS & CAGE WORK...EMAIL ME @ THEMISERY666@AOL.COM OR CALL 646-529-6423
89 coupe
interior
gery interior
rear seat delete
suspension
front
bbk c/c plates
rear
double adj upper
single adj lowers
rear end
spool
4:30 gears
